communication problem on gs-98/96/92
  • communication problem on gs-98/96/92
    Hello.
    First of all i need to explain what machine have this problem. I have machine made of mixed parts of gs-92 (electrical boxes), gs-96 (parts of frame) and gs-98 (pinholders and sweeper). Problem is that i have no communication between machines and vector server. Heart beat light on frameworks is flashing like it would have palpitation. We had problems with the plug in the gamesetter box and i thought that it would be it, but after changing the plugs problem was still present. Cables were checked and then double checked. Changing electronic board inside the gamesetter box also didn't help.
    I will be gratefull for any tips.
    With the GS CPU, the red button needs pushed down to activate communications to the scorer.
    Detector Rod Adjustment
    The New Brunswick NXT
