I'm Stumped, Need Help...?
  • I'm Stumped, Need Help...?
    I've tried EVERYTHING I know to do guys. The shark switch isn't working and the 10 pin, pin holder isn't working but everything else IS working. For the 10 pin holder, I've changed it out with a new one. I put a brand new wiring harness on both top and bottom. I even tried switching a pin holder on another machine I knew worked with this one just to check to see if the part was good and not faulty and nothing worked. As for the shark, I put a brand new shark assembly on it cylinoid and everything. I put a new pin count switch on it as well and wiring harness that runs to pin count switch and everything on the left hand side. Nothing worked. I then went on to change the I/O and motherboard out and that was a no go. They have shipped bad boards to us before though. Does anyone have any fresh ideas or have had this problem before by chance? Im baffled. Any suggestions would be a huge help thanks!
    Sounds like you have an issue with your f5/f6 circuit. I had this issues once, & it was the ball door silonoid wire shorting everytime the sweep dropped. Check fuse/inspect the 10/ Shark/ball door areas/unplug-replug & troubleshoot.
    F5 (RH Pinsetter) F6 (LH Pinsetter) - 10 Pin Gripper - Solenoids: Shark Solenoid, and Ball Door Solenoid
      I agree, I would those fuses f5 & f6
      IT'S CARNIVAL TIME!!!
        Sounds like a blown fuse or even check your table cable.
          if you are running 98s then its the cpu board and my guess it will be CB5
          im never wrong just askme
            not cpu i/o board my mistake
              GS-X?
              If the boards are working and all LED's are lit, it could be the transformer. Left for the odd lane, right for the even lane.
              Quickest way to check this is turn the power off, swap the molex connectors over and turn back on. Problem should move to the other lane.
                Sounds like a transformer fault. You can swap the plugs over and see if problem moves. If it is a transformer there is a really good guide on here on how to fix them.
                  Definitely agree with Cyclonus. I have had that a few times same issue as well as even not setting the 1.2.3 pins. Replaced I/O Transformer and all good
                  • SHAWN B
                    NEED HELP ON A NEW GSX
                    by SHAWN B
                    When I have the lane being bowled on I keep getting a 05 error. When I put it in diagnostics to run it will set everything but the 5 pin, then I get 55 error code. I have noticed...
                    07-11-2008, 03:09 AM
                  • 2423
                    Pin Holder issues
                    by 2423
                    Having a problem with one pin holder looking for any ideas. Half the time it sets a pin on the table for a new rack it knocks the pin over. So far have done the following...
                    04-19-2007, 10:40 PM
                  • Spain on vacation
                    7-10 Pin
                    by Spain on vacation
                    Hi guys Im on my vacation, but at least twice a month I check the center. The 7 and 10 pin on lane 6 is not loading first, also the grippers are not openning, I just want to check...
                    07-02-2003, 11:35 AM
                  • Ricky T
                    Having consildated issues..
                    by Ricky T
                    Hey guys, I have this pin holder on Lane 21 that won't accept a pin from the pin station, nor if I manually place the pin in the pin holder, the pin holder won't release the pin....
                    08-02-2014, 11:05 PM
                  • stephen_hands
                    mystery
                    by stephen_hands
                    hey guys
                    over the past few hours we are getting a few problems with 2 of our lanes at one point the pin is loading into the pincup and then when the table goes back...
                    02-06-2011, 01:13 PM
                  Oil in gutters
                  C1 Pinout drawing
                  Finished the C1 drawing.
                  Thanks Felix.
                  If you see any...
