Random appearance of Error 50-59 in Diag mode
  • Random appearance of Error 50-59 in Diag mode
    Hi guys I have strange issue during gameplay, and in diag mode it's signed by Error 50-59. One of my GSX sometimes doesn't set up new set of pins. I was looking for solutions for this issue.
    ABC Switch are ok, solenoid looks ok. where can i look for solutions? Cable, electronics on mainboard? What i could see, sometimes solenoid can't back.
    Any help?
    Greetings
    Check the pin detector plate for proper positioning. Is it level from left to right.
    Check the Stroke Limiter height adjustment.
    Check the setting table levelness.
    Check the angle "1" and "2" adjustment.(Pinsetter Timing)
    Check stroke limiter shock.
    let me be myself
      code 50 and 59 are the 9 and 10 pins not detected in diagnostics i would be checking the pin detector plate adjusting bolts first just to make sure they contact switch on standing pins and then from there check the pinholder switches
      im never wrong just askme
        Also make sure the black clip that holds the white switch down inside the pinholder is secure all the way down and not loose. A loose switch can be giving non detected readings
        • referee
          PO error code
          by referee
          Using GS-X pinsetters.
          I have a machine that I keep getting a PO error code on. I know that PO is pins out of range, but every pin is sitting dirtectly on their...
          06-11-2010, 05:32 AM
        • purgarp
          Error codes 64,65,74,and 75
          by purgarp
          Have a good G Switch and a good SM switch. Lane blacks out and throws out code 75 doesn't load 4,5,6 pins. Put pins in pin holders get a code 64. Reset lane and gets either of...
          06-29-2016, 05:44 PM
        • referee
          PO Error Codes
          by referee
          I have a couple of my GS-X pinsetters that keep giving me a PO error code and I have no pins on the pin deck or all 10 pins are there and they are all located inside their circle...
          08-27-2013, 05:32 PM
        • avisconte
          Tough GSX issue
          by avisconte
          Alright, I'm tired of trying to figure this one out on my own so I'm extending out the issue to you and see what you guys might think.
          Here we have lane 9.
          08-06-2014, 12:36 AM
        • Steff
          50, 57 error codes
          by Steff
          We have 16 GSX pinsetters 18 months old with approx 72000 frame cycles. Last week during league lane 16 did not set the 10 pin once (as reported). Today while cleaning greenbelts...
          09-21-2011, 03:56 PM
        Oil in gutters
        C1 Pinout drawing
        Finished the C1 drawing.
        Thanks Felix.
        If you see any...
