Fax not counting pins
  • Fax not counting pins
    I have a gsx pin setter that won't count pins after 1st ball. I tried temp cable. Swapped gen boxes. Ohmed out common pin holder wire with all pin holders. All good. Table down on pins circuit closed. Table off pins circuit open. Any help would be appreciated
    thanks jim
    Check your table hight from the pin deck and the distributor.
      have you checked the oor switch
      im never wrong just askme
        Well I got it. The ABC cam was out of adjustment.
        That's a first
        thank you for your help
        jim
        Oil in gutters
        C1 Pinout drawing
        Finished the C1 drawing.
        Thanks Felix.
        If you see any...
