spotting tong switch (66)
  • spotting tong switch (66)
    We have a problem with the error code 66. it seems there is a problem with the switch or anything associated to th spotting tongs. we have replaced the switch, the motor of the table and we have checked the tooth racks of the table but nothing seems to work. the table falls in error when the tongs dont close. the table moves up a small bit and then the error occurs.
    anyone have had an issue like this? hope you can help me.
    kind regards,
    gerard
    kind regards,
    gerard
    justaskme
      Do you hear a grinding noise before it shuts off? I know when I used to get 76 errors a similar thing would happen. Putting a rubber hose washer in between the big gear on the table and its normal washer has always fixed that issue for me. We normally have the ST timing turned off on our machines and just use the switch cluster for timing so we don't run into 66's
        Watch the machine from the top and see if the rack moves off the switch lever. IF that is stable, then I would trace the wire cable and connection points and look for a loose pin or chafed wire.
          loadtoad will double check the wires. Bking4242 but how do you turn the st timing off? and wont that chance anything in the routine of the machine. cant find anything about this in the manual or internet
            I'm fairly certain you need to have a newer version of the Firmware installed to be able to turn the ST switch off. FIRMWARE v4.97.02 P/N:47-862877-403
              FLEmechanic and my lane knowledge does not go that far haha. i guess i'll run the wires and check them. otherwise i wouldn't know what to do about this issue
                Check your "B" reed switch for proper adjustment. Check the right hand harness to make sure female terminals are not opened or gaped. Check to make sure your clutch isn't too tight and clutch solenoid is engaging!
                  you didnt change a tong by any chance if you did could be the wrong tong as there are left and right hand tongs
                  im never wrong just askme
                    By any chance the tong clutch solenoid been changed?
                    just keep in mind the solenoid is in a angle correctly this may not be able to engage correctly
                    i had this problem before where it would engage but not make the full rotation
                    • phill_h
                      j1 error gs-10s ts1 switch problem
                      by phill_h
                      hello i am a amf man roped in to fix gs-10 in a 12 lane centre thats been left to fall to peieces with no mechanic on site fopr around 5 years, fault is table won't come all the...
                      10-14-2008, 02:02 PM
                    • danieljefferson
                      Error 66 Problem
                      by danieljefferson
                      Hi,
                      I am having a problem on one of my lanes, when first ball is thrown the pinsetter begins cycle. When spotting tongs close to grab remaining pins on deck and sweep...
                      05-29-2014, 06:54 AM
                    • gwJRAW
                      Blackout 76
                      by gwJRAW
                      So we have an issue with a lane, the ball goes thru the beam and the gate doesn’t drop and it doesn’t score on the league. The lane blacks out with the error code of 76. Shut...
                      12-05-2018, 08:26 AM
                    • TonyWarren
                      Error 66
                      by TonyWarren
                      About to walk out closign the building, the lane started doing a 66 code, went ahead and took easy step of replacing the ST switch.
                      However it still doing error code, when...
                      09-11-2011, 01:11 AM
                    • referee
                      PO error code
                      by referee
                      Using GS-X pinsetters.
                      I have a machine that I keep getting a PO error code on. I know that PO is pins out of range, but every pin is sitting dirtectly on their...
                      06-11-2010, 05:32 AM
                    Oil in gutters
                    C1 Pinout drawing
                    Finished the C1 drawing.
                    Thanks Felix.
                    If you see any...
