Green and red belts
  • Green and red belts
    Does a Kegel red belt replace the green belt?
    I use the red belts on the sharks and crossovers. I have heard of a few guys using it on the longer runs. I prefer the orange Kegel belt for the longer ones. It is a little less "tacky"
    let me be myself
      what billman said
      Broken key
      Recently had to overhaul a Jap A2 gearbox. I found this shattered key to be the cause of the problem.
      Anyone wanting to have a guess at
      A) Which...
      MONITOR COLOR ISSUE!!
      Pin spot is off
      4" PVC BOW EXTENDERS
      As requested a couple pics and detail of my setup. I started installing these 2 years ago after I got tired of those rubber hose extenders that would just bend. I watched and...
