Error code 72
  • Error code 72
    I keep getting the error code 72 Switch C expected but not found. I shut it off and back on. The table goes down like it’s detecting the second ball and right back up. Doesn’t want to switch to first ball and set a full rack. What can I do to fix this issue?
    Check the motor reverse fuse on the main board. You might move the table motor to another lane and see if the problem moves. I have had table motor brakes get weird and cause a lot of different problems.
    let me be myself
      check the reed switch with the setting on the nextgen with a magnet could be that or the motor or fuse like billman said
        The CAM can be out of timing or broken
        Upgraded Motor Contactor
        C1 Pinout drawing
        Finished the C1 drawing.
        Thanks Felix.
        If you see any...
