GSX Pin Holder Finger Install
  • GSX Pin Holder Finger Install
    Is there a secret to getting the finger out of the pin holder without cutting off the pivot point?
    In messing with a holder and wanting to figure things out, even with pushing in on the little tab that looks like it holds the finger in place, the shaft was too long to pop it out. Am I missing some other little trick here?
    I just push in the retaining tab gently with a small flat screwdriver. Then slide the finger slightly to the side and lift up the side that came out of the retaining tab.
    let me be myself
      I do recall I had one that I had to pop out the white dampener.
      let me be myself
        hmm, okay. Just seems that these ones just don't have enough room. I'll pry harder.
          There's a locking tab on the spring side that holds it in...
          "Don't expect too much and you'll never be let down..."
            Yeah, I had asked this question with the first one I was messing with because I wasn't putting enough arse into the tab -- afraid of breaking it I guess. Anyway, with the second I just didn't worry about breaking the tab and was able to get the finger passed the tab and pop it out.
            Gentle isn't always efficient evidently.
              I just use a round or right angle pick to scoop it out from the tab side and it should come straight out
              • nnll
                5 pin
                by nnll
                If the 5 pin falls in the chute when the deck is down it is not releasing the new rack when the deck comes back up. If i lift the 5 pin out and drop it again it works fine. Any...
                11-14-2012, 06:53 PM
              • Travis75
                right hand blocking finger
                by Travis75
                okay, i'm 99.9% sure i've found the problem i've been having since i replaced the turret on this lane, of course i've thought that before... at 180 the long will not budge with...
                07-20-2007, 11:44 PM
              • drhose
                Right hand blocking finger
                by drhose
                I have a machine where the lever on the end of the shaft for the right blocking finger will end up behind the stud of the left deck post after it has been adjusted. Any ideas...
                02-11-2006, 02:32 PM
              • pinboys
                what's the best way
                by pinboys
                I know this has been covered before but I'll be damned if I can find it What is the best way to replace the left hand blocking finger because mine has rounded it self so time...
                04-10-2007, 08:22 PM
              • Travis75
                by Travis75
                I am having an issue with a left hand blocking finger. Any time the deck is either detecting or setting new pins and a pin comes up the cross conveyor, if the pin comes over the...
                04-02-2007, 06:52 PM
              MONITOR COLOR ISSUE!!
              Pin spot is off
