GSX Pin Holder Finger Install
  • Eric Regalado
    I just use a round or right angle pick to scoop it out from the tab side and it should come straight out
  • loadtoad
    Yeah, I had asked this question with the first one I was messing with because I wasn't putting enough arse into the tab -- afraid of breaking it I guess. Anyway, with the second I just didn't worry about breaking the tab and was able to get the finger passed the tab and pop it out.
    Gentle isn't always efficient evidently.
  • RonInFla
    There's a locking tab on the spring side that holds it in...
  • loadtoad
    hmm, okay. Just seems that these ones just don't have enough room. I'll pry harder.
  • billman
    I do recall I had one that I had to pop out the white dampener.
  • billman
    I just push in the retaining tab gently with a small flat screwdriver. Then slide the finger slightly to the side and lift up the side that came out of the retaining tab.
  • loadtoad
    started a topic GSX Pin Holder Finger Install
    Is there a secret to getting the finger out of the pin holder without cutting off the pivot point?
    In messing with a holder and wanting to figure things out, even with pushing in on the little tab that looks like it holds the finger in place, the shaft was too long to pop it out. Am I missing some other little trick here?
  • nnll
    5 pin
    by nnll
    If the 5 pin falls in the chute when the deck is down it is not releasing the new rack when the deck comes back up. If i lift the 5 pin out and drop it again it works fine. Any...
    11-14-2012, 06:53 PM
  • Travis75
    right hand blocking finger
    by Travis75
    okay, i'm 99.9% sure i've found the problem i've been having since i replaced the turret on this lane, of course i've thought that before... at 180 the long will not budge with...
    07-20-2007, 11:44 PM
  • drhose
    Right hand blocking finger
    by drhose
    I have a machine where the lever on the end of the shaft for the right blocking finger will end up behind the stud of the left deck post after it has been adjusted. Any ideas...
    02-11-2006, 02:32 PM
  • pinboys
    what's the best way
    by pinboys
    I know this has been covered before but I'll be damned if I can find it What is the best way to replace the left hand blocking finger because mine has rounded it self so time...
    04-10-2007, 08:22 PM
  • Travis75
    by Travis75
    I am having an issue with a left hand blocking finger. Any time the deck is either detecting or setting new pins and a pin comes up the cross conveyor, if the pin comes over the...
    04-02-2007, 06:52 PM
Preventative Maintenance - A Jets A2 - Elevator & Pits
All this work just to clean under the elevator !!??? LOL A friend is replacing a number of his elevators as the left hand triangle plate brackets are breaking. Rather than...
Preventative Maintenance - A Jets A2 - Ball Wheel Belt Question
A friend was looking at his ball wheel belt which stated it was 208" long, (Pic 1). He was pretty sure that it is a B205 belt which should be 205" long. The answer...
MONITOR COLOR ISSUE!!
my appologies if Ive posted this in the wrong area, this is my second post on this site, Ive got a 10 lane center ( 5 pairs ) and on lanes 3&4, I am having a problem with...
Pin spot is off
I'm currently working at a 38 Lane center. Of those 38 lanes only a few are having this issue.
I'm currently trying to get all the lanes to have perfect pin spots...
Idler shaft
One of our lanes has a bad bearing assembly for the distributor pulley. The idler shaft that the pulleys sit on has been damaged where it sits on the bearing. I took the assembly...
