Continuous shutdown machine pinsetter GS
  • Continuous shutdown machine pinsetter GS
    While in manager control mode, the machine keeps shutting down. does anyone know how to fix this?
    Any codes being kicked? What model GS?
      Thanks for the reply! No codes. It just turns off. Light and activity dies.
      its a 7 series.
        If the machine isn't moving and it just shuts down when power applied, first thing to check is make sure there isn't a physical jam preventing the distributor/elevator from rotating.
        Then try to run it from the control box on that lane pair and see what kind of response it is giving you.
          Forgot to mention that in bypass it does work. Does this change the problem that much?
            Hmm. Hadn't run into this, but I'd check all the cable connections and circuit board plugs at the control box. This might be a loose, wire or connector.
              If this problem has been resolved ide love to know the outcome ! My guess would be the safety pin was left in the tower preventing the table to move
              MONITOR COLOR ISSUE!!
              Oil in gutters
              C1 Pinout drawing
              Finished the C1 drawing.
              Thanks Felix.
              If you see any...
