Continuous shutdown machine pinsetter GS
  • Mark caplin
    If this problem has been resolved ide love to know the outcome ! My guess would be the safety pin was left in the tower preventing the table to move
  • loadtoad
    Hmm. Hadn't run into this, but I'd check all the cable connections and circuit board plugs at the control box. This might be a loose, wire or connector.
  • gerard_-_brand
    Forgot to mention that in bypass it does work. Does this change the problem that much?
  • loadtoad
    If the machine isn't moving and it just shuts down when power applied, first thing to check is make sure there isn't a physical jam preventing the distributor/elevator from rotating.
    Then try to run it from the control box on that lane pair and see what kind of response it is giving you.
  • gerard_-_brand
    Thanks for the reply! No codes. It just turns off. Light and activity dies.
    its a 7 series.
  • loadtoad
    Any codes being kicked? What model GS?
  • gerard_-_brand
    started a topic Continuous shutdown machine pinsetter GS
    While in manager control mode, the machine keeps shutting down. does anyone know how to fix this?
Preventative Maintenance - A Jets A2 - Elevator & Pits
All this work just to clean under the elevator !!??? LOL A friend is replacing a number of his elevators as the left hand triangle plate brackets are breaking. Rather than...
Preventative Maintenance - A Jets A2 - Ball Wheel Belt Question
A friend was looking at his ball wheel belt which stated it was 208" long, (Pic 1). He was pretty sure that it is a B205 belt which should be 205" long. The answer...
MONITOR COLOR ISSUE!!
my appologies if Ive posted this in the wrong area, this is my second post on this site, Ive got a 10 lane center ( 5 pairs ) and on lanes 3&4, I am having a problem with...
Pin spot is off
I'm currently working at a 38 Lane center. Of those 38 lanes only a few are having this issue.
I'm currently trying to get all the lanes to have perfect pin spots...
Idler shaft
One of our lanes has a bad bearing assembly for the distributor pulley. The idler shaft that the pulleys sit on has been damaged where it sits on the bearing. I took the assembly...
