little tip for repairing switch fingers
  • little tip for repairing switch fingers
    Because i haven't seen this one here yet i share this with you:
    This can be done with 16mm wire end sleeve, fits perfectly and can also be applied to build in pinholders.
    Good day!
    Nice.
    • Bobbie_Bees
      Pinholder Microswitch
      by Bobbie_Bees
      Going through the machines at Lucky 9 Lanes here in Richmond, BC, I've noticed a few things with the micro switches in the pinholders.
      The original micro switch is...
      02-09-2018, 12:24 AM
    • vinson
      Mechanics Tip
      by vinson
      Here's a tip for you,
      before installing a start switch -micro switch . Wrap a it a couple of times with electrical tape before installing it. That way the switch will last...
      02-11-2002, 12:35 AM
    • toon30s
      Switch Grips
      by toon30s
      Turbo 2 n 1's switch Grip thumb slugs. Anyone selling them? Good or bad??
      06-20-2006, 01:45 AM
    • Guest's Avatar
      switch b
      by Guest
      hey guys im a learnin on the 98's just ask Imitchel lol. but anyway on lane 24 tonight had a machine that kept blacking out after the 10 pin only would be picked up. i would...
      03-13-2001, 12:54 AM
    • Sal
      Bypass Switch
      by Sal
      Does anyone know where there is a wiring diagram for the bypass switch in the rear of the wire channel next to the mechanics switch?
      Thanks.
      05-14-2003, 02:02 AM
    Broken key
    Recently had to overhaul a Jap A2 gearbox. I found this shattered key to be the cause of the problem.
    Anyone wanting to have a guess at
    A) Which...
    MONITOR COLOR ISSUE!!
    Pin spot is off
    4" PVC BOW EXTENDERS
    As requested a couple pics and detail of my setup. I started installing these 2 years ago after I got tired of those rubber hose extenders that would just bend. I watched and...
