58 in diag
  • 58 in diag
    have a weird issue with one of our lanes in diag we get a 58 which is the 8 pin( in scorer it will give you 1 point even if you gutter)
    i have already checked wires on table with meter all check out fine
    ive replaced the pin holder a couple of time with one we rebuilt and i know work i swapped the one in question to another lane and it works
    iv also swapped out the io board on the next gen still the same thing
    pin loads into pin holder and sets pin down but just wont detect it
    as soon as table come down to detect pins errors out 58
    wires were checked as table went up and down also
      So you checked the harness and table cable? No chance of the micro switch on the pin holder being loose giving false readings? If the i/o boards were switched and the problem still occurred, maybe the CPU board can be bad.
        change your detector plate or adjust the bolt
        im never wrong just askme
          micro switch is in properly no play on it it also passes meter test
            plate was replaced when i replaced the holder
              When you switch the holder, was there anything at all that you reused? If not the only other thing I would think to check is the table levelness or the stroke limiter quality/adjustment
                holder was a rebuilt(we rebuilt it) one we had with new parts except for solenoid and micro switch.
                they are in working order since i can put(rebuilt holder) it on another lane or in another pin spot and it works.
                the one i removed originally also worked fine since its on another lane and hasnt had any issues
                if the stroke limiter or table level was of it would probably throw more than just an 8 pin error.
                we had an issue like that before when the table wasn't leveled correct and would give out multiple errors
                  since you say no wires broken pin holder all good try putting table down to pin detection and then check the 8 pin detector plate it has to be somewhere where the switch isnt being activated
                    Adjust the pin detect plate bolt by lengthening it. This allows it to make contact a little sooner.
                      Not an option on GSX machines. The plunger/plate distances are fixed dimensions.
                        Has to be the table cable. There's going to be a bad wire. Check for continuity and you should find your problem. If not, then look for bad kinks in the wires. Try to pull wire in half, if it breaks then it's bad if not then it's good. Use a good amount of strength. Then just solder back together
                          Given that the GSX is a change of state single switch, and the switch IS getting the signal through to show loading of pin, I would look at the table-nexgen cable. Specifically, the part in the plastic tube where it bends back up to the machine from the support. There is a chance that the wire for the 8 pin switch is damaged and when stretched (table at detect height) it's breaking signal. Quickest thing to do is swap it with the next lane over and see what happens.
                          There are a few other things I'd look at, but given you've changed the holder with a known good and also changed the detector plate, it is unlikely to be there. The only exception to that is check the microswitch retaining clip. I've seen this slightly loose on some holders and the hole switch is moved rather than engaged on detect.
                          Oil in gutters
                          C1 Pinout drawing
                          Finished the C1 drawing.
                          Thanks Felix.
                          If you see any...
