GSX POO Switch Mod
  • GSX POO Switch Mod
    Just a quick question for all you who have worked on GSX machines, have any of you thought about, or have, modded your machines POO switch from the micro switch to using a magnetic reed switch? i never really liked the concept of how Brunswick placed their offspot switch, and the actual mechanics behind it too. I would have thought using something non-contact would be more efficient. Curious about all of your thoughts...
    Have not thought having the current setup as being an issue. Cannot really see an advantage to substituting a pass by type sensor. That said, if the OEM setup had a pass by sensor and I hadn't run across major problems (neglect aside), I'd not look to change it either.
    My view.
      Seems to me those reed switches would have to be close to work, & would break every time they got accidentally hit. I'm with you on it looking wacky, but I've only had a handful of issues with them & they were quick & easy to remedy.
      • Twebb
        GSX Shark Switch
        by Twebb
        Hi, got a little problem with one of my sharks, it is not switching at all. ive tried changeing the shark for a working spare, changing the nexgen box and i have traced the continuity...
        12-17-2009, 11:09 AM
      • jday
        GSX Pinholder Switch
        by jday
        Since our machines are coming up to 9 years old I have been replacing the plastic part that activates the pin holder switch. (the one with the spring and 2 bumps) I have found...
        11-16-2009, 05:13 AM
      • TheWrench
        J1 codes
        by TheWrench
        Hello everyone. I'm new to these GSX machines. Having a machine that throws a J1 code. I thought I had found the issue but I guess I havent. I move the pin cups vertical to horizontal...
        03-20-2015, 06:45 PM
      • Guest's Avatar
        switch b
        by Guest
        hey guys im a learnin on the 98's just ask Imitchel lol. but anyway on lane 24 tonight had a machine that kept blacking out after the 10 pin only would be picked up. i would...
        03-13-2001, 12:54 AM
      • Pindecked
        RANT: Quality BE. SS start switch...
        by Pindecked
        I 've used these for a long time( 15 yrs) ..lately, If I order 5 of them...3 don't work right out of the package. Also the directions say "Long black to terminal...
        08-23-2005, 10:43 AM
      Oil in gutters
      C1 Pinout drawing
      Finished the C1 drawing.
      Thanks Felix.
      If you see any...
