Blackout 76
  • Blackout 76
    So we have an issue with a lane, the ball goes thru the beam and the gate doesn’t drop and it doesn’t score on the league. The lane blacks out with the error code of 76. Shut the lane off and turn it back on, it swipes the pin and grinds the spotting tong gears. Why does it do this? Any ways to fix this action?
    Code 76 means that the machine is looking for the spotting tong switch but it is not being actuated. Check everything that involves the spotting tongs including the switch.
    let me be myself
      Do a search in this forum for grinding tong gears and 76 codes....there are numerous threads that deal with your issue. Solenoid, gears not meshed properly, switches out of adjustment, gaskets, etc.....
        The main gear for the spotting tongs would be causing kickback or grinding. Look for broken teeth. On the same gear there's a smaller gear underneath it, which can also be missing teeth. It would help to take it off and place a rubber washer underneath to prevent the grinding.
        • Bearded_Stu
          spotting tong adjustments + 76 error
          Bearded_Stu
          How to you all set up spotting tongs?
          I've gone through the Brunswick Manual, and to be honest, it's a little vague. It says to fully close the tongs but the gear...
          09-06-2010, 03:27 AM
        • Ray Andrews
          Code 76
          Ray Andrews
          GS-98 / I keep getting a code 76......after the tongs pick up the pins and sets them....the tongs open and then crank back to the closed position JUST enough for the tab to go...
          06-03-2003, 01:46 PM
        • davegargamel
          76 codes
          davegargamel
          So lately I've had a couple o' machines give me 76 error codes. When I go to the pinsetter, sure enough the cam is off the microswitch actuator. While watching these offenders...
          11-29-2007, 02:04 AM
        • stephen_hands
          76 code
          stephen_hands
          hey guys
          one of my lanes keeps coming up with a <span style="color: #FF0000">76 code </span>and a have checked all the spotting tongs and gears...
          10-11-2011, 12:54 PM
        • LaRu
          Spotting Tongs
          LaRu
          I have been having a problem with a lane dropping pins. We have adjusted the tooth racks, stop blocks, spotting tongs, and replaced some spotting tongs. The problem seems to...
          06-18-2008, 01:24 PM
        Upgraded Motor Contactor
        C1 Pinout drawing
        Finished the C1 drawing.
        Thanks Felix.
        If you see any...
