GS pin holder micro/snap action swtches
  • GS pin holder micro/snap action swtches
    Does anyone have a Grainger , Mouser or any other company out there part number for the switches in the pin holders? I think GS 96 and 98s are the same not sure about the GSXs.
    Thanks in advance
    47-053635-004 Micro Switch (single, cherry) 47-054700-004 Micro Switch (double)
    im never wrong just askme
      Thanks but I don't want the Brunswick numbers.
        Do you have the number on the side of the switch. Or post the measurements of your switch specifically the mounting hole dimensions. Perhaps a picture. These are commonly available just need to know what you have. Sorry, not a GS mechanic but just trying to help.
          matsu****a am50010c1 70314N 0.1A 250 vac or D41X D.1(0.05)/250 40T85 5E4 125-250 vac thats the only 2 style switches i use
            This appears to be what some suppliers are selling as a replacement. You can check out the datasheet here. I'll leave it to you to verify it matches your needs but it appears to be what you are looking for.
            Question: Is the double switch a different switch or just two of these side by side? This switch is advertised as a replacement for both switches.
            https://www.mouser.com/ProductDetail...n3hoM8C2mz4%3d
            This also seems to match what justaskme posted when comparing dimensions. The operating force seems to be a little higher but I don't think that will be an issue.
            Let us know how it goes.
              Here is a screen capture with the part number in case the link becomes inactive in the future.
                This is this link to the switches I ordered from Grainger. Will let you know how well they hold up. Thanks for the help guys.
                Looking for HONEYWELL 15A @ 240V Pin, Plunger Miniature Snap Action Switch; Series V7 (24A259)? Grainger's got your back. Price:$1.89. Easy ordering & convenient delivery. Log-in or register for your pricing.
                  I have been using Grainger #24A294 for a while now with no issues
                    The ones I ordered from Grainger were way to stiff
                      just ordered a couple Outlaw2020. Thanks
                      MONITOR COLOR ISSUE!!
                      Pin spot is off
