Ball Accelerator
  • Ball Accelerator
    How complicated is it to uninstall and reinstall a ball accelerator on a GSX? Also as well as changing the belt on it? Does the belt ever snap in half or become undone off the wheels? Lastly is there any tutorial video on how to do so?
    its fairly easy to pull out ball accelerator have to undo rear bolts both ball rings and wedges remove bolts holding the kickback and remove the bolts holding accelerator to the ball track and then you should be able to pull the accelerator out don't forget to unplug ball door solenoids , to remove accelerator belt undo the adjusting bolt which in turn will loosen the spring remove the belt change the front hub if needed or what ever your going to do put new belt on and adjust the tension back up to 194 mm . i have never had a belt snap in half before ive only replaced 1 belt in 10 years but have pulled all my accelerators out to replace the tubes that go over the rails
    im never wrong just askme
      Not sure about a video, might be one on youtube if you search there.
      Accelerator assembly.docx
        Tubes that go over the rails is my least favorite job.
          yeah, tubes are more irritating that doing A2 lift rods in my opinion.
          • HouseBall
            Ball Accelerator issue
            by HouseBall
            I have an accelerator. When a ball goes through it, it goes through slowly. It still gets the balls to the lift. Right now, I'm running this unit with out a ball wipe because...
            09-17-2011, 11:44 AM
          • Corbo
            Ball accelerator belt
            by Corbo
            I am having a problem with a Columbia White Dot, and it is just this one ball, not the brand. It is causing the long accelerator belt to move so far right that it's knocking off...
            11-19-2016, 11:13 AM
          • Guest's Avatar
            Ball accelerator
            by Guest
            It seems like when some plastic balls go threw the accelerator the belt jumps towards the little motor belt to the point that it throws the little belt off. I looked at the tracking...
            11-26-2001, 12:04 AM
          • jaysen
            ball accelerator
            by jaysen
            what is the best way to adjust the long belt on the ball accelerator. ive only changed 1 belt before and went by the book and it was a pain. is there an easier way? im also slowing...
            10-21-2004, 04:56 PM
          • Guest's Avatar
            ball accelerator problem
            by Guest
            We have some jap machines which have the accelerator belts,and on a particular pair
            a ball will cause the belt to shift over to the
            right and knock the accelerator...
            09-01-2004, 05:39 AM
          MONITOR COLOR ISSUE!!
          Pin spot is off
