J1 permanent error!
  • J1 permanent error!
    Quisiera saber la descripcion del trabajo...!!!
    your j1 switch faulty ,or swing shaft jamming
    im never wrong just askme
          Thanks, but this "J1" is the message displayed on Consolidated CPU when Start power...
          Any idea of what part to check in that PCB?
            GSX pinsetters with Consolidated CPU boards...
              unplug the J1 turn machine off and on and see if the message disappears if so then its the switch if not then move i/o board to another lane see if problem follows
                Ok, I'll do that!
                Thanks a lot
                Jose
                MONITOR COLOR ISSUE!!
                Pin spot is off
