Gs-92-98 Ball accelerator
  • Gs-92-98 Ball accelerator
    Hi.
    I have problem with Ball accelerator on one of our Old gs-92-98 machines. It start running right after tuning on the hv box power switch even if both machines switches are off.
    Thanks in advance for help.
    the relay for ball accelerator is shorting give it a tap if it releases the I say you need to replace the relay as terminals are burnt
    im never wrong just askme
      It helped. Thank You kindly.
      Bind in deck hook linkage
      GS-X table bolts/stud
      Other that...
