If you are seeing this you are not logged in to Bowl-Tech. Remove this notice by Registering or Logging in
By your continued use of this site you are agreeing to the following.
You are over the age of 18, have had supervised training in safety and operations for the equipment you work on. Bowl-Tech does not warrant or guarantee the accuracy of information found on this site. Bowl-Tech, its officers and site Admins, Mentors and Guides will not be responsible in the case of losses financial or otherwise as a result of use of ANY information on this site. Posts on this site are allowed by registered members and each registered member is responsible for the content of their posts.
If you can not agree to any of these terms of use above or are not at least 18 years of age you are asked NOT to visit Bowl-Tech or utilize its content. To visit the Bowl-Tech Terms of Service and Rules CLICK HERE
Hi.
I have problem with Ball accelerator on one of our Old gs-92-98 machines. It start running right after tuning on the hv box power switch even if both machines switches are off.
Thanks in advance for help.
When we turn on the pinsetter with the power on to the ball accelerator it pops the breaker. If we turn the switch off that links the power to
the ball accelerator and...
We have a lot of arsehole's who like to bowl when the machine is off.. Hence causing us under lane ball jams.
Is there any way that I can keep the machines running but only...
I am wondering what the dimensions are for cutting out a hole for the pins to fall through when they travel into the accelerator pan? I searched on the archives for 20 minutes...
Does anyone have the spec,s or spacing that a accelerator needs to be from the y switch. I have several that does not feed the ball in smooth. I will get a lot of ball bounce...
I'm having a problem with the deck holding hook lifting up and not engaging the pin during 2nd ball cycle. At first, I thought it was the detector but have ruled that out. If...
I know I'm not the only one who has had the table bolts literally shear off. I cannot explain where there would be a force strong enough to do this to the bolts.
Other that...
Hi everybody, I'm looking for some guidance. My GSX machines have a problem with pins gathering in the table in front of the #3 pinholder. One or two lanes are worse than the...
One of our lanes has a bad bearing assembly for the distributor pulley. The idler shaft that the pulleys sit on has been damaged where it sits on the bearing. I took the assembly...
We process personal data about users of our site, through the use of cookies and other technologies, to deliver our services, personalize advertising, and to analyze site activity. We may share certain information about our users with our advertising and analytics partners. For additional details, refer to our Privacy Policy.
By clicking "I AGREE" below, you agree to our Privacy Policy and our personal data processing and cookie practices as described therein. You also acknowledge that this forum may be hosted outside your country and you consent to the collection, storage, and processing of your data in the country where this forum is hosted.
