Have you guys ever had to shave off part of the gripper that functions as a stop when they are closed? Had a call the other day where the grippers on a holder were slightly up in the closed position causing the pin to swing as the table would lower. The swinging pin would cause one gripper to open and it'd fall. I shaved the stop on it down so the grippers would be more closed but I guess it's something I should look out for when building them.
Pin Holder Gripper Question
No, have not modified the grippers that way. I have ran into only two causes for what you describe with the pins.
One is the Oring on the solenoid plunger is deteriorating and causing issues with the slide that controls the grippers.
Two is the gripper cogs are not installed properly to the slide. The cogs that are on the underside of the holder and actually hold the grippers in place can be installed one tooth off and this will cause them to not travel to close far enough.
Originally posted by loadtoad View PostNo, have not modified the grippers that way. I have ran into only two causes for what you describe with the pins.
Originally posted by Bking4242 View Post
To add to this, I've seen that issue happen with the drive sled getting hung up on the wiring or the wiring clip(which we normally remove for this reason)
Originally posted by loadtoad View PostMark Caplin -- yes, that configuration there would definitely be not good in the long run. I'd still check to make sure the teeth on the gears are timed and make modifications from there - based on your picture.
Maybe the grippers are put in the wrong holes.
Left side in the right hole and vice versa -- since the 98's are set up with different part numbers for the grippers, they are more than likely built slightly different to engineered offsets. This could easily cause issues with not swinging all the way and make it look like they "...don't have consistently positioned holes for the roll pin...."
Could be mislabeled parts numbers or just incorrectly stored parts -- happens.
Originally posted by loadtoad View PostMaybe the grippers are put in the wrong holes.
While working through the throngs of war that is cleaning up a previous guys messes I am starting to get more J1's and 1-10 calls. On each of these lanes pin holders have been...
Channel: Brunswick GS Pinsetters
07-11-2013, 10:31 AM -
by BobbyOMaybe I'm missing something but I have to ask this question. Every so often I get a call Interlock/Hanging pins.. What I find is a pin lying inbetween the rsc rail and edge of...12-18-2008, 08:42 PM
by scott31Maybe we are just missing something stupid, but on the GS-96's, is there anything that would cause multiple 4 pins to be loaded into the pin holder. We are having an issue that...
05-31-2006, 07:20 PM -
I work at my sons famly owned center on and off. The one big problem we are having is the pin holders are snapping like crazy.
My question is...could it be a bad...-
09-08-2010, 12:18 PM -
by Super ChuckWhen the pin drops from the pin station to the 7 pin, pin holder it hits in the holder and bounces out. Replaced the pin holder, replaced the pin station. The table height is...
05-12-2011, 02:17 PM -
Bind in deck hook linkage
GS-X table bolts/stud
Other that...
Other that...
