Problems
  • Problems
    I have a machine that the 7, 8 and 9 pinholders won't work i changed pinholders and that didn't help changed I.O. board and top wire harness.
    Is the stroke limiter solenoid working?
      Will that make the 7,8,9 pins not work
        The 7-8-9 & stroke limiter solenoids are on the same circuit. If it's not working (table won't do a full stroke), you likely blew the f3 or f7 fuse in the nexgen. Replace the fuse, & if it blows again check for a bare wire going to the 7-8-9 holder or much less likely the stroke limiter solenoid.
          Ur a genius it was stroke limitersolenoid not working
          Bind in deck hook linkage
          GS-X table bolts/stud
          Other that...
