GSX NexGen firmware
  • GSX NexGen firmware
    Has Brunswick released a newer firmware update with the "Coast back to A" feature? What I've got currently is labeled version 4.97.02, part number 47-143094-400, dated Feb 2016. I've got Coast Past A but not the setting that returns to A. I noticed the newest catalog has a different part number (47-862877-403) but the picture still shows version 4.97.02 printed on the label.
    It's been on all the new boards we've gotten, haven't seen anything officially announced though.
    Bind in deck hook linkage
    GS-X table bolts/stud
    Other that...
