Replacement cable
  • Replacement cable
    Hi all. I need to make up a replacement cable from
    the sweep release solenoid to the nex gen box. I have the molex pins but I’m just wondering is there any particular spec of cable I need to get. A replacement cable from Brunswick isn’t in stock with my supplier and I can’t wait a few weeks for one. Any input greatly appreciated.
    I would just find a 2 conductor 18 gauge stranded wire. Having the 2 wires in 1 jacket will make running the cable easier. Should be able to find this at any hardware store. I think the original wiring is 22 gauge but that may be harder to find in a store. Good Luck
      ....to piggy back on what GCM Techs said, although he shows a pic of red/black conductors -- for this application, the color doesn't matter. It can be a two conductor cord that is as one unit like a lamp cord. Main thing is the wire gauge size. Hobby store if there is one in your area would be a good place to look also.
        Thanks for the replies, I'll see what I can get hold of.
        Super Bowl Funday!
        Qubica BES-X Lane Advertising
        Making TDM's adjustable.
