Both lanes don't turn on.. HELP!!
  • Both lanes don't turn on.. HELP!!
    Hi guys, I'm new here (sorry about my english). I'm having a problem with lanes 1 and 2, we only have 4 lanes in our alley. Everything started with EJ error code on lane 1, I checked and everything was fine with the elevator. Turn the machine on again and error code 72 appeared. What happened next (almost at the same time) was lane 2 presented the same problem, now we have both lanes down. We replaced every red switch (ABC), elevator switch, io boards, transformers, energy board (motors) and com board (switches and selenoids) but it didn't solve the problem. We switch both electrical boxes or chassis (1&2 to 3&4 lanes) and the one presenting the problem (1&2) worked just fine on lanes 3 and 4 but theirs didn't work on lane 1&2. This is just giving me headaches, I think the problem might be some ciruit or part they share in common, ball accelarator? ball return? we checked everything!! we've even replaced the ball accelerator motor and the problem continues.. I really really need help guys, we depend on our four lanes to be operative to keep this place running. Any help will be appreciated.
    Johan
    sounds like your masking unit switch is off that will give EJ and 72 when machines are switched back on
    im never wrong just askme
      Thanks!! we checked that again and it turned out to be a problem with the lights (masking).. Both lanes are now working fine. Thanks a lot! problem solved.
      Super Bowl Funday!
      Qubica BES-X Lane Advertising
      Making TDM's adjustable.
