Is a GS a three phase only machine?
  • Is a GS a three phase only machine?
    Someone asked me about installing lanes at home, whether to go AMF or Brunswick. Since the A-2 is no longer made, I suggested GS if he wanted a new Brunswick. Someone told me once that they were run by 3 phase. Is this correct? How does the height of a GS compare to an A-2? Seems like the 82-90 is the only choice for a new machine if no 3-phase power is available.
    Old and obsolete? It's new to me!
    Re: Is a GS a three phase only machine?
    Not sure what phase the GS series is, but they are even taller than the A-2's. Tell your friend to buy a quality used 82-70/90/XL that way you wouldnt have to worry about height clearance problems.
      The GS series are 3 phase machines. The GS-X is called a "Tower Down" machine because it is now redesigned to be shorter. I haven't measured the height difference from an A-2, but I do think it is shorter.
      For a home owner, I think it is simpler to understand how it works.
        Well which machine has less calls? This is a rich guy with no mechanical ability and wants to have the latest and greatest. the ceiling height is 10-12 feet sloping but I think they goofed and don't have a wide entrance door. So which is simpler to understand, A-2, GS or 82-XX? As for me the 82-30 was just fine!
          The Gsx is easy to understand and so is the 82-70.
          We have gsx and they are currently running at over 6000 frames per stop.j.
          I'm a proud member of www.bowluk.com
            I was an AMF 82-70 mechanic for 25 years, last year we have changed to GSX. I was always an AMF men so to say but now Í never want another machine than the GSX. Almost no calls and a lot easier to understand. The GSX is a bit higher than an AMF machine but a bit shorter. The pit is build up in the house,
            The front end must be installed as one part.
            If you measure the with of a lane plus guters, than you know the right space you need to get it thru a door.
            If the high voltage is a problem, you can also put a transformer in.
              GSX IS BETTER THAN AMF. THE HEIGHT FROM THE FLOOR TO THE TOP OF THE GSX I2 225 CM FROM FLOOR. WIDTH IS 160CM .
              YOU CAN HAVE A 3 PHASE OF 110 VAC OR 230 OR 415VAC. GSX IS UNIVERSAL VOLTAGE AND THE 2 MACHINE IS ONLY 6KW
              JOJO
                GSX is the way to go
                IT'S CARNIVAL TIME!!!
                  Amen brother............j.
                    GSX requirs 3 phase due to the fact that it uses the 3 phase to run some of the motors both clockwise and counterclockwise without 3 phase it would not work properly. Also with the new tower down design the GSX is approx. 2" longer and about the same height as a A2. But the GSX is much simpler to work on. My thought is if you can afford to purchase a new GSX and put it in the house you can afford to have 3 phase run into the house.
                      I service a resident house with GS-98 and they have a transformer to get the 3 phase power that is needed...I'm servicing the house tonight...I'll try to remember to get all info the off the transformer that they are using.
                        You're right 2423, it is 2 inches longer, and it's is 2-3 inches lower with the new tower down. it's 3 phase is also do to switches and solenoids, besides the table motor. GSX is the way.
                          Ok let me get this straight, 6KW for a pair of machines? An A-2 has a 1HP motor, 746W, maybe 2KW for the pair? Converting single phase to 3 phase is terribly inefficient. The home in question is in a "gated community" and has underground power, no 3 phase available. Most likely the person I put him in contact with will recommend 82-90's. I have never seen a GS machine and am not sure if any exist in south Florida. You thinx the GS will be more trouble free than an 82-90? Would he have trouble finding a mechanic?
                            No trouble finding a mechanic. If a mechanic can figure out the detector in any A machine, he can figure out the GS-X in about 2 minutes. After all, all the parts are visible without tearing an assymbly half apart...
                            "I like you. You shall die a painless death when I take over the world." Stewie Griffin
                              The resident house that I service are useing a Rotary Phase Converter from Kay Industries...Something simular to these.
                              MONITOR COLOR ISSUE!!
                              Pin spot is off
