one pin position will n ot spot
  • one pin position will n ot spot
    hi guys got a weird problem here, other night lane 15 starts not spotting the headpin. looking at gsx as one pin is dropped into pin holder the pinstation solenoid doesn't open to except pin but lane does set pins like one pin is in. changed out pinstation same problem pin is in pinstation but will not activate solenoid to set pin.thought it might be broken wire so i changed out from the connector in the station to about 12 inchs assuming i would take any broken wires out in the bends and at the station but no luck .any ideas ??????
    Are you sure it's not in the pinstation..... Could it be that you changed the broken one with a broken one also.... this happend to me some times when a pinchaser changed a pinstation and put the broken one back in stock......
      If problem is as you described, I guess that your problem is in the cable. Usually problem is in the cable from NexGen (Consolidated electronics) to setting table. To rule out cable, route one from NexGen to pinholder.
      Brunswick Authorized service provider
        Thanks will give it a try
          Okay well its not the upper cable switched it out for a new cable. I have done the following: new rebuilt pinstation, swapped pinstation from diffrent pin position old one works fine in swap swapped does not fix problem, replaced roughly 12 inchs to 16 inchs of wire past pivot point on deck still will not set pin .any ideas I am stumped.
            Na rebuilt one for it and swapped one out of diffrent pin position no affect still will not activate solinoid to set or recieve pin
              If you have swapped nexgen to table cable and swaped good working pinholder with 1 pin and the one you moved from pinholder to different position works it has to be in the table harness or nexgen box. Be sure to check the connector where the table harness and the main cable meet I have seen one of the pins get pushed back/out of connector and lose contact.
                Okay after deciding to move a known good table into 15 to eliminate everything up to the nexgen box no go same problem. So I decided to move backwards. Good table new table to nexgen box cable same problem.replace io board in nexgen box same problem. Replaced cpu guess what solved problem. I have never seen a single solinoid problem like that be the cpu huh.thanks for your imput guys.
                  Glad you found the problem.
                  Help-broken Part
                  Greeting all.
                  Thanks for looking.
                  Bolton454
                  Pin Damage
                  Making TDM's adjustable.
                  1:1 shaft wear
