pin #7 not dropping into pin station
  • pin #7 not dropping into pin station
    Hello,
    I'm having a strange problem. It all started last night when an extra pin came through the #3 spot and caused damage to #7 pin holder when the table tried to come up, triggering a J2. I changed the pin holder as it was clearly broken. When I tried to run the machine, the pin would not drop into the station. I changed the pin station and the problem persisted.
    I noticed that the pin release lever is barely being touched by the pin holder arm. I checked the table levelness and it is fine. This I do not understand. Perhaps the metal pin station frame for pin holder #7 is bent?
    Ideas?
    Adjust the pin release lever.
      Is the table height correct? 140mm +/- 2mm
        adjust the pinstation forward a bit (towards the approach)
          Check for loose wedge on rear swing shaft on 7 side
          Help-broken Part
          Greeting all.
          Thanks for looking.
          Bolton454
          Pin Damage
          Making TDM's adjustable.
          1:1 shaft wear
