8 pin loads but will not set
  • 8 pin loads but will not set
    i have a machine that will accept its 8 pin from the pin station but when it goes to set the pin-holder will not set have replaced solenoid micro etc. and i do know that it isn't the wiring harness have just checked it anyone have any ideas?
    U check the harness with the holders in spotting position or laying down? Sounds like a wire is loosing contact when the holders flip to set
    could also be the table cable loosing contact when it's stretched out when the table goes down
      i have actually tried that already and have actually fix the problem by adjusting the position at pin deck only as referred to in the manual and then the 8 pin was setting everytime thanks for you help anyways!!!
      Qubica BES-X Lane Advertising
      Ball Damage at my wits end
      GS-X table bolts/stud
      Other that...
