Tube deck not coming all the way up
  • Tube deck not coming all the way up
    Tube deck suddenly doesn't come all the way up? Run it all the way down and look at the chain shown with red tape here. The chain should be tight. If it's loose as you see here the chain shown with the blue postit may have jumped a cog. It's less likely but possible that one of the sprockets on the shaft at the left side of the first pic may have broken its key and turned on the shaft. I didn't exactly reproduce the condition for the pics. I lowered the tube deck onto a couple of 2X4s laid edgewise.
    Are you hearing any abnormal sounds coming from the machine at all? Have you checked the sprockets on another machine to compare them to?
    http://www.youtube.com/profile?user=Bowler4Ever
      This happened years ago. I recreated it to show how it could happen and how to deal with it.
      Ion buffer brush
      Have Kegel ion model B. Noticed the buffer brush rubbing up against the felt that's attached to the oil transfer assembly (the "door" you open to fill the tanks). This...
      Upgraded Motor Contactor
      C1 Pinout drawing
      Finished the C1 drawing.
      Thanks Felix.
      If you see any...
