need specs on a duckpin
  • need specs on a duckpin
    Could someone give me the specs of a duckpin ? Or a link to a website with them ?
    Thank You
    I would go to http://NDBC.org and email them. This is the National Duckpin Congress, they should be able to give you specs.
      http://en.wikipedia.org/wiki/Duckpin_bowling
      If you want find any else on duckpins google it.
        I have a rubber band duck pin and a duck pin with out rubber band. If you need measurements give me a shout.
        Pins getting gouged
