funk string machines
  • funk string machines
    hi guys,
    does anyone know about the funk brand string machines (10 pin). some people here are interested in these machines and I would like to have a look at the operation or instal manuals.
    any help would be appreciated.
    Regards,
    Len.
    Put Funk in the search box. There are some video links and quite a bit of discussion.
    Detector Rod Adjustment
    The New Brunswick NXT
