Ball return Hand fan part number
  • Ball return Hand fan part number
    I need to order a cage hand fan for my ball returns. Used part # 252-001-066. Is there another part number for this? Stahl's was the only one I could order and I could not order from QubicaAMF? Does anyone know of another part # or option? They are c90 returns with profile racks.
    Found this, should be right:
    115 volt version - 53-860359-002
    230 volt version - 53-860359-003
    Also, if you look up in the search, there are plenty of results.
    MONITOR COLOR ISSUE!!
    Pin spot is off
