Motor saver from Bowtronics
  • Motor saver from Bowtronics
    Have anyone have them in use and about how much does it save on utility bill?
    Re: Motor saver from Bowtronics
    I have used them in a 36 lane bruns A-2 house and although the difference in the electric bill was not available to me, the over all improvement in motors lasting longer and parts, especially elevator and turret, lasting at least 40 percent longer was great. I also used the bowltronics solid state motor contactors and that also helped greatly due to reduced amp draw on start up. I recommend them highly.
    I was in that center 12 years and I never had one unit go out or fail.
      A great item to add to your machines! I had 28 lanes of them.
      billman
      let me be myself
        24 lanes five years now, no complaints!
        <--- Start 'em young!
          i've noticed this seems to be a common topic lately. i dont have any of these but would like to have them.
          as i see it not only are electric costs rising and parts costs rising but it also seems like less parts are aviable. anything that helps in the least bit will make it much easier to stay in business through the next few years.
          the parts are what i see the most value in, i was comparing our parts supplier to mosquitos the other day. without us their dead, aand they arent helping us to survive.
            We have them on 64 pinsetters ( 2 houses ) and no complaints. If it is the PS-1 that you are refering to. Great product.
            Mark
            (919) 757-1789
              great idea, however, if u know what u are doing, you can make your own. i did that to 4 lanes now at half the cost, and does the same thing. no taking away from bowltronics, i just like doing things on my own too. if anyone is interested in pics let me know, i'll poast them up.
              the "Shermanator"
                rollerdj:
                Lets see what they look like.
                Do have schematics too?
                Steve H
                  schematics in my head. i can possably draw some up. i'll also include parts list.
                  the "Shermanator"
                    i'd like to see your setup also. i want these things but if i can do it myself at half the cost, sign me up.
                      haha. i'm just trying to nab the camera off the wife. she's a teacher and uses it a lot for her class. i'll steal it on my way though to work. basicly i got two allen bradly time delay off moduals, (will post up part numbers when i get back) a small 4 pole N/O ice cube relay, and a small 2 pole N/O ice cube relay. we still have the old A style electronics in our pinsetters, so i went ahead and updated the relay for the cycle sylinoid to an ice cube style while i was in there.
                      the "Shermanator"
                        ok, the AB part number is 700-FEB1SU22. It will take two of them. Be carefull of your wiring into it, as it takes multipal voltages. A1 needs to go to the coil of the cycle sylinoid relay, A2 goes to the transformer for a constant 24V source. B1 is common ground, then 15 and 18 is the switched side that controls your motor starter. The second time delay is wired the same way but goes to a N/O push button to manually start the motor. The four pole ice cube relay now has the pit light on it on top of the other two circuts on it. I have my time delay set at 2 min right now, but I'll most likely drop it to a min and a half. I've been running this setup for a little over a month with no problems to date. I'll post pic's later tonight or in the morning for everyone to see.
                        the "Shermanator"
                          got a cost estimate for building one of these?
                            your looking at around 40 / 50 bucks per TD unit. 12 bucks I think for the ice cube relay, and about an hour of yur time.
                            the "Shermanator"
                              Thats going to be one of my next biggest projects to my pinsetters.
                              My frameworx scoring has a conserve energy feature, but i want to shut those off as i do this...
                              Mike
                              Detector Rod Adjustment
                              The New Brunswick NXT
