Highway 66
  • Highway 66
    Hello all. On one of our highway 66 lanes, the first to be exact. When we boot up every morning it turns it self to the "game settings" menu. All we have to do is just get out of that screen and everything works fine. It’s not causing any other problems (for now.) It’s just annoying. Anyone have a idea why this would happen, they are only a year 1/2 old. Thanks.
    - Albert Einstein
    Re: Highway 66
    I have just had 4 new lanes of highway 66 installed. This was happening on all of my lanes. The installers had wired up the menu button inside the console wrong on both pairs. The q-AMF engineer just swapped some wires around on a follow up visit and every thing was fine. May be somone at your center replaced a microswitch or the wires just came off and were put back the wrong way around. How are you finding your HWY 66 system in terms of reliability etc? Have you had many problems, had to replace any parts? Do you have a regular maintenance schedule ?
      Re: Highway 66
      I will have to check that out. We have not had any major problems with them. Just the occasional pin breaking off the string. I have had to replace a ball detector sensor, a slot interrupter sensor and a break solenoid. That’s about it, other than someone throwing a ball through a monitor. We have the plastic glass installed over them now.
      - Albert Einstein
      Pins getting gouged
