Not so popular Pinsetters
  • Not so popular Pinsetters
    How many different Pinsetters are there
    Google come up with a few not so common ones like
    AIM and Odin what others are there
    Then there are a few on Alibaba that claim to be refurbished or are they Chinese copies
    There's a mendes pinsetter that uses a magnetic table. Pretty cool
      Bowl-Mor Corporation made Pinsetter for both Candlepin and Ten Pin Bowling. in the 60's and 70's There are Shermad DUckpin pinsetters on the east coast.
        and they make a Brunswick A2 with a missing silencer cord on the pinwheel sound quiet...
          Furukawa.
            there are bowmor ducks as well. we still run 8 of them. they are simular if not identical to the 10-pin machine.
              Whereabouts are you? I'd love to drop in and roll a few next time I'm in the area.
              "Oil patterns?!? We don't need no stinkin' oil patterns!"
                im on the cape the house with ducks is on rt 44 in raynham. originally 24 lanes, then 16, now 8 ducks and 8 a2's. they are going to be replaced by candles soon, but i dont know when its gonna happen.
                  Don't forget Double Diamond. They made a five-pin setter, and maybe a tenpin as well? Can't remember.
                  Toby
                  82-70B, Stepper chassis
                  www.mooseexchange.org
                    I don't believe DD made a ten. A 5 for sure, and remember the Jayne Candlepin? There was a device!
                    Doug
                      How about.....
                      AMF 82/95 Candlepinspotter
                      http://www.bowltech.com/forums/showt...ndlepinspotter
                      Brunswick A50/A51
                      http://www.bowltech.com/forums/showt...=brunswick+a50
                        Of AMF (82-70) clones, there are the VIA and Xima from China, the Italian born Switch - a Via with their updates, and the little seen Korean model with a chain driven distributor.
                          What ever happened to that hydrolic A-2 pinsetter? I remember seeing it at Bowl Expo - probably 8 years ago or so in Orlando.
                          Marty - Pro Bowl West
                          56 Jap A-2's Qubica VDB's
                          2 Kustodian Walkers
                            I think it was called the Speigel or something like that. It was a maroon colored pinsetter. I never did see it run, but I did see it at Expo twice when in Vegas. Both times there was some "reason" why it wasn't able to run that year.
                              I believe it was the Dacostar????
                              Not sure, but here is a pic I found with a google search...
                              Detector Rod Adjustment
                              The New Brunswick NXT
