Scissor stud tool.
  • Scissor stud tool.
    Not sure if they make a special wrench to hold the stud for the scissors, but my dad got tired of fighting with it and made this wrench. He cut down a 15/16 wrench, grinded the face down and fixed a magnet in the backside. It rests flush on top of the stud and can place it to where it can be hands free. Thought I'd share..
    Coooolll.....
    Ive cut a 15/16" wrench in half so as to give a little more manoeuvrability but never thought of a magnet.
    Thanks for sharing.
      I bought a 15/16" short combination wrench from Craftsman. I also never thought of a magnet. Good idea.
        The trick is to machine ( grind) the angle on the wrench face so it sets flush on the scissor and the deck plate.
          My father is a welder/metal fabricator. I bought a standard 15/16 wrench and he set it up to my specifications. I let my co workers down back use it.
            I just took a pawn shop 15/16 and bent the open end part about 5 degrees to line up with that thin nut/spacer head. Anybody remember the old sixties distributor wrenches that wrapped around to time car engines? Same idea.................
              Magnet is a nice add on!
              John
              804-240-4982
                Brunswick just came out with one
                Pins getting gouged
