Pit Board Rubbers
  • Pit Board Rubbers
    Years ago, got tired of these damn things falling off. Here's my fix. Never come loose again.
    1/4" bit centered on metal strap.  Try to avoid area that rests on upper frame. Spade bit, drilled to just above strap. Mark new hole, drill 1/4' hole, countersink other side for 1/4 allen bolt. Apply contact cement, wait, then bolt together. Done, won't fall off again.
    There is also a very good replacement from PPP, (Pinsetter Parts Plus). I put their earlier version on, (used a clamp on each end), many many years ago and have never touched them again. They make two heights.
      Anything that improves the original manufacturer idea is AOK with me.
      I gave up purchasing urethane products to shim the pit board. I use pine timber, its cheap, readably available and has similar duro as urethane however it has one benifit over urethane. It won't deteriorate with time.
        In a pinch I've used some kicker strips, even cardboard to keep it working. I'll have to try that instead. I've also seen a complete replacement for the shaker, it's a conveyor belt. I can't remember who makes it, but I saw their promo video on YouTube. Weird stuff.
        Ethan Campbell
        Technician 1
        Main Event Entertainment - Plano
          Conveyor belt for A2 https://www.youtube.com/watch?v=bRmhgTJGEOY
            That's pretty cool. Any idea what it costs. My guess... if you gotta ask, you can't afford it.
              \Don't think it ever became a selling product.
                I agree HP, yes it seems like some of the urethanes do not have a long "shelf Life". They go so long and then just completely deteriorate or explode,(like my ball wheel roller from another post). I went back and checked mine, they don't appear to be urethane luckily. Pretty sure these were put on 30+ years ago when urethane wasn't as widespread. I've also clamped the the old rubber block, (and front blocks), to the frame with good success. Just grind a shallow groove in the middle for the hose clamp. Once the board is on top of it, it can't really go anywhere.
                I installed a number of the green urethane buckets back in the early 80s, ( I put the date right on the bucket when I install it). Last year they all failed except for one by literally falling apart. They would rip right off the mounting bolts.
                  I never had a problem with urethane products up untll the last 15 years or so. Must be a different formula they use these days. The pit board shims are some of the worst for longevity.
                  Pins getting gouged
