Preventative Maintenance - Brunswick A, Jet, A2 - 1 Amp Fuse
  • Preventative Maintenance - Brunswick A, Jet, A2 - 1 Amp Fuse
    Anyone see a bulletin from Brunswick or have any information about replacing the 1 Amp Slo Blow Fuse with a standard 1 Amp Fuse across TS1 - F & G. It seems the departed mechanic at the Rear Wall House had removed all the slo blows and put a standard 1 Amp Fuse in. I informed the owner of this a few months ago when I was checking his electrical boxes and wiring in the mechanic's bypass switch. Just the other day we found a whole jar of 1 Amp Slo Blow fuses....go figure. Opinions ?? He has not had a problem blowing the standard fuses. He had one machine that intermittently would have the contactor flicker, so the mechanic disconnected the 1 Amp fuse ????? That was an easy fix - it was a simple adjustment of the Turent Jam Switch.
    I'd put the slow blow fuses back in. I've had standard ones blow for no reason
    The older the part, the STRONGER it is.
      All of our centres use 2A FB fuses on the 240v side. I've only ever heard of FB fuses used for that purpose...at least in Australia. There was a topic on the subject not long ago.
      I don't intend on converting to mini breakers on the 230V circuit because of their slower response time.
        I'm guessing FB is Fast Blow? I did an advanced search and didn't find that before I made this post, and thanks for opinions and info folks. Maybe the 2 Amp helps reduce nuisance failures while still giving a relatively quick open for a real fault.
          You want to use slow blow fuses with inductive ac loads such as transformers, solenoids, relays/contactors, etc. This is because of the high current spikes when and ac induction load is energized. Relays and transformers aren't as bad as solenoids because they don't have moving plungers but it's still an issue and can cause the nuisance fuse blowing problems that Nirvana experienced. People then end up putting in a larger fuse which makes the fuse futile. The slow blow fuse has two different elements to protect the circuit. One that blows quickly in the event of a short circuit and one that blows slowly in the event of an overload. This allows them to handle the brief spikes yet still provide protection. Brunswick's recommendations from the service manual are shown below. I'm not aware of any service bulletins changing this.
            The 2 amp is for Japanese pinsetters. They also come with a 5 amp for the 24 volt instead of a 3.2. I wouldn't replace a 1 amp with a 2 amp. Replacing the 5 amp and the 3.2 with 3 amp breakers did work out fine for me.
              The 2A FB fuses pre-date my employment. My predecessor was a seasoned Mech and must have had a reason for it. The centres also have a mix of US, Jap and German machines. I've only ever had the 2A fuse blow when it was necessary. We also changed to 4A fuses (SB) on the ELV side after installing ZOT rake trip solenoids; again, pre-dating my employment, which could be as long as 22 years ago?
                Only slow blow fuse I ever used was in the century oiling machine and the star shield trannny. Though they do seem to be gaining in popularity.
                I hesitant to guess the % of calls contributed to electrcial faults but the number would be insignificant.
                  I have 1 1/2amp AGC (fast blow) fuses in my boxes for the HV, and breakers for the low voltage.
                  Before and After
                  Pins getting gouged
