Preventative Maintenance - A Jets A2 - Parts Identification
  • Preventative Maintenance - A Jets A2 - Parts Identification
    I've been encouraging the owner I'm instructing to learn the names of the parts. When he calls with a machine glitch, I can't help him much if I don't know what he is trying to describe. We have to speak the same language and I'll be the first to admit I don't remember all the names and have to go back to the manual or parts book so that I quote the right thing. This also goes for folks making posts on this site. We can't help if we are not sure of what someone is describing. Also the model of the equipment, serial number, etc. is very important. The more info you give us, the easier it is to give the correct response. To that end I located my old test sheets from school in '74. We were given a test just about everyday initially on parts identification. All those quizzes are here in Parts ID All c.pdf (Could not find #1 so if someone has it, may want to add it). Also added ID 7_8 as a separate file as it didn't transfer well into the big document. The "A" contains answers, "B" is a blank answer sheet, the small "c" is my way of keeping track of Compressed files. A second file called Parts Identification contains pics of the various assemblies to help learn part names. Happy testing.....LOL
    ALL Files Scanned with MALWAREBYTES PREMIUM Version 3.3.1.2183 and AVAST INTERNET SECURITY Version 18.1.2326
    Parts ID All c.pdf Parts Identification.pdf Parts Identification.doc Parts ID 7_8.pdf
Detector Rod Adjustment
The New Brunswick NXT
