208v Transformer
  • 208v Transformer
    I changed out a transformer today wire for wire but I made an assumption regarding H1-H5 on the new unit. My question is how do I verify that H1 is H1, H2 is H2 and so on? I assume there is an Ohm reading across the coil but I don't know what the values are.The transformer that I have, has no markings saying which is which and its becoming rather frustrating to say the least.
    Thank you as always Gentlemen.
    Here is a thread from the past regarding A2 Transformers you might find helpful, a post by cobalt breaks it down
    http://www.bowltech.com/forum/pinset...n-instructions
    Mike Wilson
    Bowl-Tech Inc.
    Detector Rod Adjustment
    The New Brunswick NXT
