Clutch Reset Lever Bearing Replacement
  • Clutch Reset Lever Bearing Replacement
    Checked out the bearing cross reference but couldn't find the exact replacement. Looking for a bearing number for the clutch reset lever bearing without the stud. I see that bearing number r4a is nearly identical, anyone know if that one would work? My usual distributor is out of them, so looking to find it locally. Thanks!
    The bearings I use are R4A.
    I use those in the detector also.
      Yes, same as the hook selector bearing.
      Upgraded Motor Contactor
      C1 Pinout drawing
      Finished the C1 drawing.
      Thanks Felix.
      If you see any...
