machine not coming on ..........
  • machine not coming on ..........
    Have machine ( A2 ) that will not come on, machine turned off, pin chasers at first thought that it had blacked out, it appears not to be blacked out, all fused good and the micro sw seem to be working as they should. It will not turn on up front or on the back with the switches. I do not have control voltage at the coil on the main contactor or the motor start. main breaker is good, voltage to top of the main contactor, however with all belts removed, I did push the contacts closed motor will start, but no deck light even though it is on set of main contacts. I feel like I may have lost the 24 volt on the transformer. had to replace it not long ago at same time we rplaced the rectifier when it burnt up. hate to say it, but I think I have lost my touch in truble shooting this problem
    HELP !!!!!!
    Coby
    ANYONE WHO HAS NEVER MADE A MISTAKE HAS NEVER TRIED ANYTHING NEW
    Double check fuses with meter.
    Check masking unit switch, and molex plug going to masking unit.
    Recheck deck and turret jam microswitches.
    Deck jam switches have been known to "move" away from the jam cable button.
    Is the jam cable button lined up with the jam switch?
    Lift turret a few inches and let drop back onto support rods.
    These can get caught in the raised position.
      Found the problem, bad 1 amp fuse holder, not making connection on the internal part of the fuse holder.
      Coby
        Good catch!
        Mike Wilson
        Bowl-Tech Inc.
        Oil in gutters
        C1 Pinout drawing
        Finished the C1 drawing.
        Thanks Felix.
        If you see any...
