oil level glass leak
  • oil level glass leak
    What is the best method to remove the oil level glass? I am inquiring for another center and they have model A pinsetters. Many thanks.
    Howard
    empty the gearbox oil and using a spanner undo the oil level glass nut or if you have a large enough socket would be easier may have to drop off the release lever and gearbox dashspot been a while since i worked on those
    im never wrong just askme
      Definitely socket, extension and ratchet. I had one break when trying to remove. Twisted the top straight off it leaving the threads in the box. When replacing, just a snug fit is all that is needed.
      If the glass is being removed to clean it, consider making a dipstick to measure oil level and forget the site glass.
        http://www.bowltech.com/forum/pinset...ake-a-dipstick
        Lonnie's description is on point!
          Yep. Agree with Lonnie. Not many times I disagree with Steve but, this is one of them. Using a dipstick is much easier than maintaining the sight glass.
            what size socket? Thanks.
            Howard
              1-1/4"
                many thanks to all that responded.
                Howard
                  Here's mine.... I had to tag it "SAVE !!" as the former owner would toss anything he didn't think needed to be there. I made a number of special tools to remove broken deck bolts which were always located in a tray next to my tool box. One day I came in to find the entire tray had been thrown out !! I asked him if he knew where they were. He said: In the dumpster as they had been on that shelf for years. I told him I had been replacing broken deck bolts for years and this was an ongoing project. He just shrugged his shoulders and walked out.
                  ALL Files Scanned with MALWAREBYTES PREMIUM Version 3.5.1.2522 and AVAST INTERNET SECURITY Version 18.4.2338
                  • BryanV21
                    Changing Oil
                    by BryanV21
                    I'm getting ready to change the oil in the gearboxes of my pinsetters. They are A machines. The old mechanic here recommends 90w GL-4 gear oil. He also recommended getting the...
                    12-15-2010, 09:20 AM
                  • dothan
                    oil for gearbox
                    by dothan
                    what is the best oil to use on the gearbox. i order from amf which i believe is 600w but my mangager wants me to use what they have before which is 140. i think that is to ...
                    09-18-2010, 11:41 AM
                  • alzgarvin
                    What oil for B-10 gearbox ?
                    by alzgarvin
                    The manual calls for Brunswick Speed reducer oil. The gearbox says 30w oil. If just 30w oil should it be non detergent or detergent ? The oil in it has an odor similar to 90w...
                    06-22-2014, 07:31 AM
                  • MGens
                    Gearbox oil
                    by MGens
                    Wanting to check gearbox oil levels knowing some are probably pretty bad. I have heard that you want to change/filter them every 100,000 frame (looking for broken off brass from...
                    01-28-2016, 11:43 PM
                  • TheWrench
                    gearbox oil
                    by TheWrench
                    hey guys, i have jap a/2's and was wondering what motor oil i can use for my gearboxes. im about to do my draining of them soon. thanks for any answers
                    11-30-2009, 07:45 PM
                  Oil in gutters
                  C1 Pinout drawing
                  Finished the C1 drawing.
                  Thanks Felix.
                  If you see any...
