Preventative Maintenance - A's Jets - Motor Mount Adjustment
  • Preventative Maintenance - A's Jets - Motor Mount Adjustment
    I made a post in another thread, "Motor Problem", about adjusting the motor mount plate, which I call the torque plate. It prevents the M-GB Belt from coming off the pulley when the motor start torque causes the pivoting mount plate to "jump". Well I found the procedure, but Not in the Procedures or Adjustment sections of various manuals. It is in the Troubleshooting Section of 12-900900 Service Manual from 1963. Here it is.
    ALL Files Scanned with MALWAREBYTES PREMIUM Version 3.5.1.2522 and AVAST INTERNET SECURITY Version 18.4.2338
    Adjust Motor Mount Plate.docx Adjust Motor Mount Plate.pdf
    Don't know why Cute PDF Printer won't save the PDF properly but here is the revised "Doc" file.
    Adjust Motor Mount Plate Rev1.docx
      Finally got a good PDF Version.
      Adjust Motor Mount Plate Rev1.pdf
        I have these motor mounts.
        The way I have always done it (I never knew there was an actual adjustment for the plate) is to leave the two motor bolts loose, and move the plate up against the roll pin.
        I then slowly rotate the motor belt while "rolling" it off the drive pulley.
        When the belt does come off the pulley, I tighten the two motor bolts.
        It is more than 1/16" gap, but I dont have any belts flying off either.
        Oil in gutters
        C1 Pinout drawing
        Finished the C1 drawing.
        Thanks Felix.
        If you see any...
