"B" Moving Deck Shaft Repair
  • "B" Moving Deck Shaft Repair
    Have a moving deck lift shaft the bazooka mount plate has bent. The owner straightened it quite a while ago, now noticed the rake pull rod was hitting the bottom of the bazooka, turned the rod, closer inspection the 4:1 taps it too. Any luck putting it in a press to straighten it, then weld some side plates to reinforce it? Would like to save the 5 C-note new part cost. (The 2 C-note used babys have all left the nurseries checked).
    How far from the mounting hole does the bend start?
      Will measure it up when get to that center, next couple of nights. Thanks.
        What is a "Bazooka Plate?"
          I'm guessing these are Jap A2's?
          Seen plenty of bowed A2 lift shafts but never the mounting leg. Elongated mounting holes but never a bow or bend.
            I believe he is referring to the plate that is part of the lift shaft that comes up to the spring tube circled in the pics below. I've never seen one bend so you might want to check if something is hindering free movement. All I can say is try it and see what happens. A plate sistered to it should make it stronger.
              I would also try some of the part distributers ... Schemm Bowling may have them and the prices on used equipment is more reasonable. Some of the later manufactured steel is somewhat questionable. I have seen a number of failures on my Japanese machines that never occurred on my old 1957 Green Monsters. The early Japanese bearings were not very good either. Had a number of failures on them when Brunswick began supplying them. Quit buying them and went to a local bearing house to buy American bearings. I wouldn't be surprised if we see the same thing with Chinese steel and bearings.
                The reason i ask about how far from the hole the bend is is because if the bend starts at the hole you can perform Lonnie's mod by cutting the tip off at the bottom of the hole http://www.bowltech.com/forum/pinset...t-modification
                If it's lower I'd be inclined to straighten it and weld a support brace.
                If however you can obtain a used one I would go that route as has been suggested.
                  If the hole is bad or you break it near the hole you can buy a Zot kit instead of welding if you want.
                  • jim seay
                    Deck lift shaft
                    by jim seay
                    Just before leagues were done tonight, I got a call from the front desk, "The deck on Lane 7 is coming down crooked!" I got on top of the machine first, and it was just...
                    01-18-2007, 11:47 PM
                  • jaysen
                    deck lift shaft problem
                    by jaysen
                    i have a lane that was not picking up standing pins.long story short. i found that the 7 pin side deck lift shaft bearing was laying in the y- switch,the bolt was broken off,the...
                    04-12-2003, 10:49 AM
                  • Farrow77
                    Weird deck jam
                    by Farrow77
                    Not sure if this is what is causing the issue, but I'm having a lane that had some very random deck jams occur. To get it back into working order all I had to do...
                    08-04-2016, 10:35 AM
                  • Stevo
                    deck lift shaft
                    by Stevo
                    got a respot on 40 tonight...when i get to the machine, the back half of the spring guide tube is on the floor next to the huge frikkin spring....im glad i wasnt around for that...
                    07-12-2008, 04:34 AM
                  • PJ
                    Deck lift shaft
                    by PJ
                    Have a deck lift shaft to be swapped out (bad bearing). Does anyone have good procedure for the job. Have only swapped one in 27 years and that was a long time ago.
                    05-26-2011, 06:35 AM
                  Oil in gutters
                  C1 Pinout drawing
                  Finished the C1 drawing.
                  Thanks Felix.
                  If you see any...
