Turret release lever obsolete?
  • Turret release lever obsolete?
    I cant believe this part is obsolete. 12-150214-000 Turret release lever assembly. Is there any replacement for it. I called my distributor and they say is obsolete. It shows obsolete in the parts catalog. I gues I have to find it used? Anybody had this problem?
    Contact Ed Fox at EBN Services. He has used parts as well as new. Should be able to hook you up.
      or Tom Schemm, Schemm Bowling 888-724-2695
      Silly ?, why would you need one? Can you replace the worn parts on the old one?
        Perhaps because of a bad deck jam?
        Needed a part number for the rod ends for the connecting link between the hook selector and sweep hook bell crank using the online parts catalog and noticed the rod ends and link are no longer available. There are many part now listed as NA.
          It just broke, How? I don't know, My guy in back never told me. I contacted Ed Fox He has some used. Thanks.
            Only ever had one broken. That was because I didn't connect the spring to it before raising the deck. 2 pin snapped it clean off and I didn't have a spare. Had to ring around and then drive 200 km to borrow one from anothet centre. Right on quittin time!!
              It will break if you step on it.....
                I know if you step on me, I'll break and I am also Obsolete, kind of dried up and wrinkly.....LOL However, I called my supplier Schemm, and they stated, the part IS still available. They also have used ones for sale.
                  Take it to a welding shop and get it Heli-Arced or Tigged together.
                    I’ve noticed that too in the online parts book. Not a good thing. Especially those ones with an NA next to part number.
                    The older the part, the STRONGER it is.
                    Oil in gutters
                    C1 Pinout drawing
                    Finished the C1 drawing.
                    Thanks Felix.
                    If you see any...
