managers control cable pin outs
  • managers control cable pin outs
    Does any one have the pin out for the cable going to the cp3 plug on brunswich a/a2 machine. I need the pin outs for the cable from the curtain wall to the box. I am converting from jap machine to us and just need the colors for a,b,and c pns. I amusing black white green 3 wire so sable
    thanks
    Coby
    ANYONE WHO HAS NEVER MADE A MISTAKE HAS NEVER TRIED ANYTHING NEW
    CP3 to CN3 Don't know what year or Serial # your machines are, but this should be applicable.
    ALL Files Scanned with MALWAREBYTES PREMIUM Version 3.6.1.2711 and AVAST INTERNET SECURITY Version 18.6.2349
      Using the two attachments below, the following applies. You would want to confirm your setup is the same.
      A Blk - Counter
      B Wht - Switch
      C Grn - Common
        I guess I didn't give you the info you wanted. Thanks exM. Here is the Japanese schematic in case you need it in the future.
        Schematic Japanese Electrical Wiring.pdf
        Detector Rod Adjustment
        The New Brunswick NXT
