ZOT Bolt-on Wishbone Brace Permanent Repair Kit
  • ZOT Bolt-on Wishbone Brace Permanent Repair Kit
    Anyone used this repair kit on Brunswick model A pinsetters that were special machines made for the narrow ball return? We have these special machines and last night we lost a wishbone on the 7 pin side of the right machine of the pair. This is the side that has the steel plate instead of the normal "pipe" style frame. Many thanks for reading my post.
    Howard
    ...looks like the repair kit will work, got into it far enough today to confirm. Many thanks for reading my post.
    Howard
      Update, had to cut down the steel plate frame a bit with a sawzall, will need to figure out a new way to support the wooden plank that is between the machines above the ball track.
      Howard
        Thanks for the update Howard. I'm sure it will come in handy for future future members.
        Let us know how it holds up.
          Snap some pictures and post them of what you have. Curious to see what's going on. I never tried the kit but though about building my own every time I had to weld the bracket back on. But then I welded the bracket on and forgot about it until next time.
          Oil in gutters
          C1 Pinout drawing
          Finished the C1 drawing.
          Thanks Felix.
          If you see any...
