Hello with finding this p/#??
  • Hello with finding this p/#??
    KIMG1473.JPG Hey guys, we have 2 lanes now I've noticed missing the top ball joint connection for the turnbuckle that connects the pit cushion links to the rake trip arm.
    I looked in the parts manual and it shows the part in one diagram but doesn't give any further information. Hell, I couldn't even find the rake trip arm identified in the book.
    Tried typing it into the Classic website and gave me 0 results
    ROD END KIT Replacement rod end kit for A•2 turnbuckle assembly. • Replace worn rod ends for optimal triggering • Instructions included
    12-860576-000 – RH 12-860577-000 – LH
      Sweet man thank you!
        Purchase from McMaster-Carr. One is right-hand thread and one is left-hand thread, you can also purchase the threaded stud from them.
        Detector Rod Adjustment
        The New Brunswick NXT
